Foscam / Port Triggering
bodean
Was told that I should first, disable UPnP option on my foscam, and secondly, have a random port for the camera, but have that as an internal port. Then have a range of ports that go out to the internet (for security reasons).
Is this an instance where I would use port triggering? In the past, I use to just port forward the internal foscam port, but I've read this isn't the most secure way to handle it.
in the port mapping table - you can define the internal port, and it does not need to match the outside facing port..
Ok, so I just make a range for the external ports under port triggering?
I wouldn't do that - but perhaps the internal port is 80 (as an example) - so one assigns the InternalIP:80 out to port 8080 on the other side - NAT and port mapping will allow that to happen..
To connect then from the outside - ExternalIP:8080.... again, this is just an example...
NAT is fun ;)
It doesn't have to be a port for port map...
So your saying don't mess with port triggering, and just use the port forward option? Heard that is less secure, especially for web cams
port numbers won't fix a broken web cam - perhaps better to not expose it all together - rather, vpn in and look at the pretty pictures from the trusted LAN side..
