I currently have freenas running on an old computer, booting off a thumb drive with 2 TB drives raid 1 (geom mirror).
I was thinking about buying a QNAP 4 bay or something because I really want to consolidate things here...keep current NAS for file storage, media streaming, itunes but start using iscsi and connect my VMs there.
However, the prices are pretty high on off-the-shelf solutions.
after running across the ss4200 here in the forums, I was thinking it could be cheaper to pick up one of those and build a new freenas box...
I'm wondering how a ss4200 might perform in comparison to..say the qnap 439 pro... anyone compared them?
I figure if the performance was decent my plan of attack would be to order the ss4200 throw a couple 1.5TB drives I have in there and install FreeNAS 0.7 on a DOM to create a new mirror (maybe even look at ZFS). Then I would rsync my data from the old 0.69 freenas box to the new box. Lastly, I would move the 2 1TB drives into the new 0.7 box and create another raid1 array for my VMs and maybe time machine or something. That would leave me with just the SS4200 a 1.5TB mirror and a 1.0TB mirror...I suppose I will need to check out ZFS more though because maybe I would need to add the other 1TB drives in differently, as long as the end result was the same, data storage and iscsi for VMs and maybe even time machine backups.
I would really like to boost performance a bit as the speed on the current box hasn't been that great, however, I want to scale down from the size of the tower and the noise
...current box is:
FreeNAS 0.69 Kwisatz Haderach (revision 4276)
Platform i386-embedded on Intel(R) Pentium(R) 4 CPU 2.40GHz (2411MHz)
500MB RAM
500MB RAM
