Hello,
Looking at purchasing a good router.
Our house is not fairly big, however it is big enough that the router placed next to the entrance door would not extend at the back of the house / first floor.
We have used a Netgear PoE solution which has done pretty well, however it is a bit unstable at times.
As we are doing some renovation work in the house I had been able to lay a conduit from the office located at the back first floor all the way into the front room, I already purchased a 20 metres sFTP Cat7 cable.
The plan is to get rid of the PoE and install a router in the office, but which router is the dilemma!
What we need is:
- good 5 GHz uplink / downlink, as we are working from home on some days and I do data heavy stuff
- good 2.4 GHz downlink, as we'd like to be able to have a good wifi in the garden at the back of the house
- good NTFS USB3.0 read/write, seeing as modern technology allows it I would like to use the router as a NAS (I am aware it is limited, but rather than dashing out another £200, I'd rather start off with a router and see how I get along)
Also, it would be great if it has many LAN ports and a budget of ideally under £100, can stretch to £ 150 ($130, max $195)
Because of all of the above requirements, I selected the below routers:
Linksys EA8300
https://www.smallnetbuilder.com/wir...-stream-ac2200-tri-band-wi-fi-router-reviewed
good DL 5 GHz, ok-eyish DL 2.4 GHz, not great overall UL, " Meh storage performance" (as the review reads)
Linksys EA9300
https://www.smallnetbuilder.com/wir...-stream-ac4000-tri-band-wi-fi-router-reviewed
I'd pick this for the good read/write results
ASUS RT-AC86U
https://www.smallnetbuilder.com/wir...86u-dual-band-ac2900-wireless-router-reviewed
Good read performance, 2nd best write performance for the budget, good 2.4 GHz DL, not great 5 GHz DL though, quite good 5 GHz UL. It seems overall a good option
Phicomm K3C
https://www.smallnetbuilder.com/wir...mm-k3c-ac1900-mu-mimo-gigabit-router-reviewed
outstanding 5 GHz UL, good 5 GHz DL, outstanding 2.4 GHz DL, really sucky read/write performance, only 3 Ethernet ports, at a fraction of the other contenders though. Also, new brand >> uncertainty on support etc.
Can I have some opinions from someone who knows particularly well these routers / has them/ is experience enough to dash out some advice?
Thank you
What we need is:
Linksys EA8300
Linksys EA9300
ASUS RT-AC86U
Phicomm K3C
Thank you
