FVS336Gv2 allow external dhcp server
Tekniqueman
I'm very confused, the FVS336Gv2 is attach to 2 different ISP: WAN1 is connected to a fiber modem 100/100 mbit connection, and WAN2 is connected to a Zyxel Prestige 2601HN-F1 in brigde mode with 20/2 mbit connection. that'll say if I attach the Zyxel to WAN2 then the LAN become unstable with dropouts and slow performance. I can see on a windows pc that IP addresses is released and internet connection disappear constantly, and the ip-address it shows is from the range the zyxel DHCP gave before it was conf. as a bridge, so somehow the zyxel manage to let its fomer IP range pass through the firewall. The FVS336Gv2 is setup to loadbalancing. If only WAN1 is connected all is fine.
How do I get stabillity when I use both connections?
I'm pretty certain you must configure PPPoE on the WAN2 of the Netgear when the Zyxel is bridged.
