Gaming router recommendations
slick8
Im looking for a good gaming router, im running my gaming rig via wire but i need it to be wireless so i can use a laptop occasionaly, i tried the netgear 3700 and was not impressed, im using a engenius 9850 but it just too quirky any ideas? thanks
Unless you're willing to put up with unpredictable periods of high lag, you should forget wireless for gaming.
If you must go wireless, try 802.11g, not N. G is much more stable. Any router will do.
my game machine is not wireless, i want wireless so i can use my wireless laptop in another area of the house
What are you trying to do with the laptop that is causing you to be not impressed by the two routers you have tried. The WNDR3700 is one of the best N routers available in terms of wireless performance.
You may DrayTek Vigor 2130n which is a Gb WAN router. SNB gave it a review early this year with over hundreds Mbps. They also claimed Vigor 2130 earns around 800Mbps at their lab, check it then...
Do you work for Draytek? In a 30 minute period you just bumped up over 1/2 dozen threads from the past with replies pointing to Drayteks....in a rather "spammer like" fashion.
He registered with a Taiwan email and IP, so it's possible.
I've PM'd him asking that he say so if he is affiliated with Draytek.
