getting openvpn-event script to bypass openvpn client
rostar99
I am trying to get a openvpn script I found that works on the Tomato router to work on my RT-AC56U. I am looking to make certain IPs to bypass the openvpn client on the router and go to the default wan instead. I believe all it needs is some changes in references in the script to work in the AC56U.
Here is the tomato vpn_route.sh that I believe is equivelant to openvpn-event in AC56U:
#!/bin/sh
if [ "$script_type" == "up" -o "$script_type" == "down" ]
then
	/rom/openvpn/updown.sh
fi
if [ "$route_gateway_1" != "" ]
then
	VPN_IP_LIST=$(nvram get vpn_client1_ip_list)
	VPN_TBL=$(nvram get vpn_tbl_1)
	if [ "$VPN_TBL" == "" ]
	then
		VPN_TBL=101
	fi
elif [ "$route_gateway_2" != "" ]
then
	VPN_IP_LIST=$(nvram get vpn_client2_ip_list)
	VPN_TBL=$(nvram get vpn_tbl_2)
	then
		VPN_TBL=102
	fi
fi
export VPN_GW VPN_IP VPN_TBL
# delete rules for IPs not on list
IP_LIST=`ip rule show|awk '$2 == "from" && $4=="lookup" && $5==ENVIRON["VPN_TBL"] {print $3}'`
for IP in $IP_LIST
do
	DEL_IP="y"
	for VPN_IP in $VPN_IP_LIST
	do
		if [ "$IP" == "$VPN_IP" ]
		then
			DEL_IP=
		fi
	done
	if [ "$DEL_IP" == "y" ]
	then
		ip rule del from $IP table $VPN_TBL
	fi
done
# add rules for any new IPs
do
	IP_LIST=`ip rule show|awk '$2=="from" && $3==ENVIRON["VPN_IP"] && $4=="lookup" && $5==ENVIRON["VPN_TBL"] {print $3}'`
	if [ "$IP_LIST" == "" ]
	then
		ip rule add from $VPN_IP table $VPN_TBL
	fi
done
if [ "$script_type" == "route-up" ]
then
	VPN_GW=$route_vpn_gateway
else
	VPN_GW=127.0.0.1  # if VPN down, block VPN IPs from WAN
fi
# delete VPN routes
NET_LIST=`ip route show|awk '$2=="via" && $3==ENVIRON["VPN_GW"] && $4=="dev" && $5==ENVIRON["dev"] {print $1}'`
for NET in $NET_LIST
do
	ip route del $NET dev $dev
done
# route VPN IPs thru VPN gateway
if [ "$VPN_IP_LIST" != "" ]
then
	ip route del default table $VPN_TBL
	ip route add default via $VPN_GW table $VPN_TBL
	logger "Routing $VPN_IP_LIST via VPN gateway $VPN_GW"
fi
# route other IPs thru WAN gateway
if [ "$route_net_gateway" != "" ]
then
	ip route add default via $route_net_gateway
fi
ip route flush cache
exit 0
openvpn Custom configuration:
script-security 2
route-up /root/vpn_route.sh
down /root/vpn_route.sh
Link to post where I got code from:
http://www.linksysinfo.org/index.php?threads/any-way-to-bypass-vpn-selectively.33468/#post-164693
I have created an "openvpn-event" file and a "vpn_client1_ip_list" file in jffs and only need guidance on what changes to get it to work. Also there is a modification to the openvpn custom configuration the starts with "script-security 2" that I do not find referenced in the openvpn-event script.
Thank is advance
#!/bin/sh
then
fi
then
	then
		VPN_TBL=101
	fi
then
	then
		VPN_TBL=102
	fi
fi
for IP in $IP_LIST
do
	DEL_IP="y"
	do
		then
			DEL_IP=
		fi
	done
	then
	fi
done
do
	then
	fi
done
then
else
fi
# delete VPN routes
do
done
then
fi
then
fi
exit 0
script-security 2
Thank is advance
This thread had a simplified Selective routing script:
http://forums.smallnetbuilder.com/showthread.php?t=9311
Regards,
Thanks for the tip. Apparently I did not search for the correct terms earlier and missed this thread. The script is working now with twelve IPs using the VPN and three IPs direct to WAN.
Thanks again.
