TM-AC1900 working in offline mode (no internet) with pop up error message constantly coming up... need help in figuring out how to suppress or turn off error message that states the following:
TM-AC1900
You failed to access to the web page that you want to view.
Reason for failed connection :
TM-AC1900
- The network cable is not connected.
- Please ensure that the cable is properly connected between the router's and the modem's WAN port.
- If a problem still persists, manually change the connection settings. Click here to go to the setup page You can check and config your setting by yourself.
