Gigabit Internet and RT-AC88U Parental Control's performance impact
Roz
Hello Folks,
I figured it's best I post this as a separate topic rather than mixing this up with my earlier post.
So basically I have a new ASUS RT-AC88U wifi router. I have gigabit internet at home from my ISP. And for parental controls/time scheduling in it to work correctly, I need to disable NAT acceleration on it. Only problem is, when NAT acceleration is disabled, that kind of caps the internet speeds to something like 300-350Mbps (even for wired clients connected to the router) while I am paying the ISP for a gigabit internet. So while I need NAT acceleration enabled to get it's maximum possible throughput, I also need the parental controls to work properly/accurately.
I do understand the technical aspects of why this is so. But my question is this:
For those you having gigabit internet at home and successfully using parental controls/time scheduling on it, what model ASUS wifi router do you use which gives you the the ability to go up to (or close to) 1 Gig speeds?
Thanks!.
