HarryMuscle
I currently have my guest Wi-Fi networks setup to allow guests to access each other but they are blocked from accessing the non guest LAN devices, which is exactly what I want. However, it turns out I also need to give my guests access to the printer which is located on the LAN.
I'm assuming this needs to be done via iptable changes (unless there's a way to do this via the GUI which would be ideal). Also since my printer has a web interface, I would prefer to only allow access to certain ports of the printer that are actually used for printing and not to open up the whole IP to the guest Wi-Fi.
Any help in putting together the correct iptable rules would be greatly appreciated.
Thanks,
Harry
Thanks,
Harry
