Go back to 3.0.0.4.270.26 ?
gLaiVe
my firmware is now RT-AC66U_3.0.0.4_374.35_4,some people said 3.0.0.4.270.26 is the best one if u don't need USB or openVPN and so on and the wireless speed and stability is the best... If i go back to 3.0.0.4.270.26 and press the Reset for 5 seconds to start a new setting,is it enough to clear all the settings? or need I clean NVram myself using command?
Be advised that firmware is old and may not have any security issues addressed that newer releases have and for sure there is no ipv6 firewall. Just a FYI.. I'm sure others will know more. Good Luck !
I really don't need ipv6 firewall,I just need stability and wireless speed and also a wol function...thx anyway:p
That's there version I am running I like it every thing works wireless USB parental controls, range is good
For ipv6 secure just disable accept ra
