Good router search tools
devinrhode2
The search tools on asus.com are pretty good, but I've noticed that the product data for asus routers is a bit shotty, leading to some routers not appearing in certain searches.
I did find a decent google search query. I wanted to discover "AX6000" rated routers, with a "4x4" antenna setup, and a "2.5" gbps wan port.
This search worked pretty well:
"4x4" "2.5" "AX6000" site:asus.com -inurl:all -intitle:all
smallnetbuilder.com also has these ranking tools.
(But they aren't exactly _search_ tools, like is present on asus.com)
If anyone has any other search tricks, share them here!
You can't find much because only some are AX6600 (GT-AX6000, RT-AX88U/Pro), others AX5700 (RT-AX86S/U/Pro), others AX6600 (ZenWiFi XT8)...
Go to asus.com.
Go to "wifi routers" from banner menu.
Filter for "wifi speed" of "AX5700 to AX11000":
Note that this device doesn't show up:
Go to asus.com.
Perhaps they heard you? I checked the page and ROG Rapture GT-AX6000 appeard. lol
Yeah it seems they did hear me..
It has appeared now, both when visiting link and re-doing the steps I outlined.
Regardless, product data overall is still shirt.
here's gif/video recording of another example:
Should be able to hire some very cheap labor to clean up this data...
I found this at the bottom of asus.com, though the filters are quite few... but may help you find the fit one?
and also found similar thing on netgear, but I think it's for orbi only
(but both are still limited to their own products)
