Graph Scale
TheLyppardMan
Just curious as to why the vertical axis on the 24-hour traffic analyser is not set to display the data better...
Probably because one of the other tabs had a spike.
Has it always worked that way? I never really noticed but now that I do it seems it should adjust the scale to whichever connection you've selected.
As far as I recall, Asus has done no change to that code in over 7 years...
