1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
  2. SNBForums Code of Conduct
    Dismiss Notice
Dismiss Notice
Welcome To SNBForums
GT-AX11000 bonding stability?
Discussion in 'ASUS AX Routers & Adapters' started by Curiousdreamerz, Jan 27, 2020.
  1. Curiousdreamerz
    Curiousdreamerz New Around Here
    Jan 24, 2020
    7
    Has anyone used port bonding on the GT-AX1100? If so, has this setup been stable? I've setup port bonding to my Synology DS718+ but wondering if it will affect the stability of my GT-AX1100. I've noticed my GT-AX11000 been a bit flaky lately, loosing internet connectivity once in a while.
  2. Gouldin
    Gouldin Regular Contributor
    Jan 30, 2015
    77
    United Kingdom
    I have a qnap ts-473 setup with bonding, has been fine for a few months now, was also fine with my older rt-ac88u.
  3. Hollidayone
    Hollidayone New Around Here
    Jan 28, 2020
    2
    Gouldin , thanks for your posts, I also have the GT-AX1100 and the ac88u, my setup works great while not using the ax protocol, with it checked I have some devices that lose connections. I’m interested in your overall impression with the ax11000.
  4. Curiousdreamerz
    Jan 24, 2020
    7
    I use to think the GT-AX1100 was a great router. However, lately with the latest 7979 its been very unstable. I reverted back to the previous firmware and now I notice that the internal router interface drops out once a day. From a hard wired workstation I can't ping my default gateway and after a reboot it starts working again. Anyone else have this issue?
