First time poster here, so hello everyone.
I'm running a GT-AX11000 with asuswrt-merlin 388.2 connected to an NBNco fttp/ftth service in Australia.
Since having my fibre connection commissioned in January, I've been subscribed to a 400/50Mbps service with my retail service provider.
The RSP gives their customers the ability to switch their service speed up and down on demand.
My 400/50 service was pretty consistently giving me 410-420/47 Mbps down/up speeds according the asuswrt built-in Ookla speedtest.
Last night I thought I'd try upping the speed to the next tier, 1000/50Mbps.
The very next speedtest I carried out showed 713/47 which I would have been reasonably happy with. However, since then, EVERY test I've carried out has given me similar speeds to what I was getting on the 400/50 tier.
I've tried rebooting the router, bouncing the WAN interface, and a full power cycle to no avail.
My RSP said Asus routers often need QoS enabled with manually configured down/up bandwidths to get higher speeds. I've tried all of the QoS options and if anything, they reduce the speeds I can obtain.
As a sanity check, I cracked open and configured the eero router the RSP sent me when I signed up and it was showing a 970/48 connection speed so the issue is definitely with my Asus router.
Can anybody smarter than me suggest any configuration settings to look at that might be impacting my connection speeds or this just to be expected?
I'm quite comfortable going down to the shell level if there's anything I should be look at there.
Thanks in advance people.
Frewster
Frewster
