GT-AX6000 and ATT BGW320-5--
GreyHawkz
I am using Asus GT-AX6000 with ATT BGW 320-500. Set it up with IP passthrough. All appears to be working well. Just wondering what are the best wifi settings on the GT-AX6000 to ensure maximum speed throughput? Thanks in advance!
Many people report the defaults work well. You'll probably have to experiment for your devices, environment, and use case.
Separate SSID for each frequency.
2.4ghz to 20mhz
5ghz to 80mhz (or 40mhz)
