GT-AX6000 WAN Port as Trunk to upstream firewall??
kstamand
Is it possible to use the WAN Port (regular or 2.5gb) as a trunk to upstream pfSense firewall?
So far I tried the following:
- WAN port, results in only VLAN1 LAN and Wireless ports working, no other VLANs receive DHCP assignments from upstream firewall)
- WAN 2.5g port configured as Trunk allowing all VLAN, nothing worked this way, VLAN1 or otherwise
Configuration is ISP -- pfSense -- GT-AX600
Goal is to be able to use all 4 switch ports on GT-AX6000 for two different VLAN + Wireless SSSID to 3 VLAN
Running latest Asus firmware 3.0.0.6.102_34810
