GT-BE98 Pro Merlin Version 3006.102.4 IPv6 Issues
John DeLuca
Hello, I seem to be having two IPv6 Issues on my GT-BE98 Pro Merlin Version 3006.102.4. The first is this loop I keep getting in the logs
jul 5 18:50:59 ddns: eth0 has not yet obtained an WAN IPv6 address.(9)
Jul 5 18:50:59 ddns: current ipv6_service: dhcp6 | old ipv6_service: dhcp6
Jul 5 18:50:59 ddns: IP address, server and hostname have not changed since the last update.
Jul 5 18:51:29 watchdog: start ddns.
Jul 5 18:51:29 ddns: eth0 has not yet obtained an WAN IPv6 address.(8)
Jul 5 18:51:29 ddns: current ipv6_service: dhcp6 | old ipv6_service: dhcp6
Jul 5 18:51:29 ddns: IP address, server and hostname have not changed since the last update.
The second issue is I don't see any IPv6 Lan info under settings. I made sure to set it to native on both IPv6 settings as I have IPv6 settings then Advanced_IPv6_Content under IPv6 tab.
That's the important bit.
Disable IPv6 updates in WAN>DDNS (automatically enabled when IPv6 is active), it doesn't work. The IPv6 WAN IP is not available on eth0, it's on br0.
Added: It doesn't work correctly on Asus firmware either AFAIK
