Ironcobra80
I am having constant issues with my asus router dropping my tp-link smart plugs. It seems looking at the logs that its resetting them every couple of minutes which is causing problems when I try to control them with my echo devices. I have attached a section of my logs and the whole thing over a couple of days showing the constant resets. Any ideas where to start. I did add all 3 of the plugs to the dhcp list giving them static ip addresses.
Jul 20 11:59:37 wlceventd: wlceventd_proc_event(491): eth6: Deauth_ind 70:4F:57:9C:79:0E, status: 0, reason: Deauthenticated because sending station is leaving (or has left) IBSS or ESS (3), rssi:-62
Jul 20 11:59:37 wlceventd: wlceventd_proc_event(491): eth6: Deauth_ind 70:4F:57:9C:79:0E, status: 0, reason: Unspecified reason (1), rssi:0
Jul 20 11:59:37 wlceventd: wlceventd_proc_event(527): eth6: Auth 70:4F:57:9C:79:0E, status: Successful (0), rssi:0
Jul 20 11:59:37 wlceventd: wlceventd_proc_event(556): eth6: Assoc 70:4F:57:9C:79:0E, status: Successful (0), rssi:-65
Jul 20 11:59:38 wlceventd: wlceventd_proc_event(491): eth6: Deauth_ind 40:3F:8C:E8:1C:02, status: 0, reason: Disassociated due to inactivity (4), rssi:0
Jul 20 12:00:13 wlceventd: wlceventd_proc_event(527): eth6: Auth 40:3F:8C:E8:1C:02, status: Successful (0), rssi:0
Jul 20 12:00:13 wlceventd: wlceventd_proc_event(556): eth6: Assoc 40:3F:8C:E8:1C:02, status: Successful (0), rssi:-75
Jul 20 12:00:15 wlceventd: wlceventd_proc_event(491): eth6: Deauth_ind 70:4F:57:9C:79:0E, status: 0, reason: Deauthenticated because sending station is leaving (or has left) IBSS or ESS (3), rssi:-63
Jul 20 12:00:15 wlceventd: wlceventd_proc_event(491): eth6: Deauth_ind 70:4F:57:9C:79:0E, status: 0, reason: Unspecified reason (1), rssi:0
Jul 20 12:00:15 wlceventd: wlceventd_proc_event(527): eth6: Auth 70:4F:57:9C:79:0E, status: Successful (0), rssi:-65
Jul 20 12:00:15 wlceventd: wlceventd_proc_event(556): eth6: Assoc 70:4F:57:9C:79:0E, status: Successful (0), rssi:-65
Jul 20 12:00:20 wlceventd: wlceventd_proc_event(491): eth6: Deauth_ind 40:3F:8C:E8:1F:AB, status: 0, reason: Deauthenticated because sending station is leaving (or has left) IBSS or ESS (3), rssi:-66
Jul 20 12:00:20 wlceventd: wlceventd_proc_event(491): eth6: Deauth_ind 40:3F:8C:E8:1F:AB, status: 0, reason: Unspecified reason (1), rssi:0
Jul 20 12:00:20 wlceventd: wlceventd_proc_event(527): eth6: Auth 40:3F:8C:E8:1F:AB, status: Successful (0), rssi:0
Jul 20 12:00:20 wlceventd: wlceventd_proc_event(556): eth6: Assoc 40:3F:8C:E8:1F:AB, status: Successful (0), rssi:-66
Jul 20 12:00:25 wlceventd: wlceventd_proc_event(491): eth6: Deauth_ind 40:3F:8C:E8:18:76, status: 0, reason: Deauthenticated because sending station is leaving (or has left) IBSS or ESS (3), rssi:-74
Jul 20 12:00:25 wlceventd: wlceventd_proc_event(491): eth6: Deauth_ind 40:3F:8C:E8:18:76, status: 0, reason: Unspecified reason (1), rssi:0
Jul 20 12:00:25 wlceventd: wlceventd_proc_event(527): eth6: Auth 40:3F:8C:E8:18:76, status: Successful (0), rssi:0
Jul 20 12:00:25 wlceventd: wlceventd_proc_event(556): eth6: Assoc 40:3F:8C:E8:18:76, status: Successful (0), rssi:-73
Jul 20 12:00:55 wlceventd: wlceventd_proc_event(491): eth6: Deauth_ind 70:4F:57:9C:79:0E, status: 0, reason: Deauthenticated because sending station is leaving (or has left) IBSS or ESS (3), rssi:-64
Jul 20 12:00:55 wlceventd: wlceventd_proc_event(491): eth6: Deauth_ind 40:3F:8C:E8:1C:02, status: 0, reason: Deauthenticated because sending station is leaving (or has left) IBSS or ESS (3), rssi:-77
Jul 20 12:00:55 wlceventd: wlceventd_proc_event(491): eth6: Deauth_ind 70:4F:57:9C:79:0E, status: 0, reason: Unspecified reason (1), rssi:0
Jul 20 12:00:55 wlceventd: wlceventd_proc_event(527): eth6: Auth 70:4F:57:9C:79:0E, status: Successful (0), rssi:0
Jul 20 12:00:55 wlceventd: wlceventd_proc_event(491): eth6: Deauth_ind 40:3F:8C:E8:1C:02, status: 0, reason: Unspecified reason (1), rssi:0
Jul 20 12:00:55 wlceventd: wlceventd_proc_event(527): eth6: Auth 40:3F:8C:E8:1C:02, status: Successful (0), rssi:0
Jul 20 12:00:55 wlceventd: wlceventd_proc_event(556): eth6: Assoc 40:3F:8C:E8:1C:02, status: Successful (0), rssi:-73
Jul 20 12:00:55 wlceventd: wlceventd_proc_event(556): eth6: Assoc 70:4F:57:9C:79:0E, status: Successful (0), rssi:-67
