Guest Access
Ebartone
Hello,
I have set up a guest ssid, password, etc and set access intranet to disable. That said, when I am on it, I can still get to the router, devices, etc. Am I misunderstanding "intranet"? Thanks.
Correction: I just discovered I was actually connected to my AP. so my base router the Ac68 is set so guest has no access to intranet, and that works. But I extended my guest with the same ssid and password through my ap which is a N66 and it gave me no option to allow or not allow intranet access on the guest ssid so by default it allows it. Any thoughts on that? Thanks.
