Need some help with the Guest Network on 2.4 GHz on AX11000 running 386.7_2 firmware.
Read a lot about people setting up Guest Network for IoT devices, so I decided to experiment with it. Also having read about various issues people have had, I decided to start clean - factory reset the router, removed all mesh nodes and manually input settings (mostly everything is default).
Connecting to 2.4 GHz, 5 GHz-1, 5 GHz-2, everything appears to work.
When I enable Guest Network on 2.4 GHz (have tried all three - Guest Network Index 1/2/3) I completely lose Wi-Fi connectivity on the 2.4 GHz band. Have tried toggling Access Intranet, but it makes no difference - no connectivity on 2.4 GHz band.
When I enable Guest Network on 5 GHz (have tried all three - Guest Network Index 1/2/3) Wi-Fi on 5 GHz Guest Network on 5 GHz both work. The issue only occurs on the 2.4 GHz.
Also, can someone please explain the difference between Guest Network Index 1/2/3? And with the Guest Network, is my understanding correct that any device connected to the Guest Network is also not routed through any scripts running on the router - Diversion, Skynet, Unbound?
Thanks in advance.
Thanks in advance.
