Solved: Downgrading Asus RT-AX88U from 3.0.0.4.388.22525 to 3.0.0.4.386.49674 fixed the issue.
Solved: Option 2 is to enable firewall
Hardware:
Using Asus RT-AX88U as AiMesh Router (3.0.0.4.388.22525, latest firmware),
Using Asus RT-AX56U as AiMesh Node (3.0.0.4.386.49380, latest firmware),
Settings:
Access Intranet = Disable
Guest network on AiMesh = All AiMesh node(s)
Issue:
Any device connected to Guest Network on AiMesh Node (Asus RT-AX56U) can ping and access devices connected to LAN on AiMesh Router (Asus RT-AX88U).
Example:
My phone (192.168.101.111) connected to the Guest Network on AiMesh Node (Asus RT-AX56U) can ping and access my NAS server (192.168.50.5).
The entire purpose of Guest Network is "The Guest Network provides Internet connection for guests but restricts access to your local network.", and it fails to do it on the AiMesh node.
Am I the only one having this issue? Does Asus know about it? Am I missing any setting that needs to be changed?
Hardware:
Settings:
Issue:
Example:
