For background, I am running three AX86U Pro mesh in AP mode, behind a dedicated firewall/router. 3006.102.4 Merlin. I have my dedicated firewall/router and managed switches figured for the same VLAN ID on the Asus. DHCP is served up by the firewall/router. The GNP works fine.
As soon as I enabled a GNP profile, even before the firewall and switch configs, I noticed that a few devices that were configured for the main network (with the main network SSID and credential) would randomly connect to the GNP network. After I set up the DHCP, I confirmed that they also received an IP address on the VLAN subnet. Mind you, these devices do not have the GNP's SSID name nor credential. It looked like the AX86UP somehow moved the devices from the main network to the GNP network.
Has anyone seen this issue? Thanks.
