Guest network via Lyra node
Neil Smith
Hi. As the title suggests, I have Guest network enabled on an Asus RT-AC86U. This is wired to node which operating via backhaul. This node is 4ft from my firestick. The FS shows full signal strength for my 2.4 and 5Ghz non guest networks but only 2/3 bars for guest 2.4 and 1 bar/nothing for 5Ghz. So I'm a bit confused considering the node is working as showing full signal strength for my 2 non guest 2.4 and 5Ghz network. Is guest known to have a weaker signal? Thanks..
bbunge
Part of the Furniture
Lyra is still on the 384 code-base. Therefore the guest WIFI will not sync to the nodes.
Neil Smith
Thanks. Seems strange that they've added 'sync to AIMesh' under guest setting on the router! Does being on 384 code mean that's a chip limitation or could they in theory rectify this over a firmware update?
ligeza
There is test version .386 for lyra so it is no chip limitation. We still waiting for official version.
