spdMerlin GUI bug in spdMerlin on Gbps+ connection?
papypaprika
Hi all,
I have a symmetric "10Gbps" fiber connection plugged in the 2.5Gbps ethernet port of my RT-AX86u.
spdMerlin reports correctly between [2-2.5]Gbps speeds, but I presume there is a bug in the "Download Data (MB)" column and the "Upload Data (MB)" column.
NB: the cli version of spdMerlin correctly reports GB of data dowloaded and uploaded.
@Jack Yaz, the Download Data and Upload Data columns should I believe be GB, or if in MB it should be 1000x more, shouldn't it?
EDIT: screenshot attached, typo
Depends. On how much has been downloaded or uploaded.
i don't think we've seen it download gigabytes in a speedtest before! should be easy enough to fix, will take a look at some point
