[GUI BUG] Samba: Maximum number of concurrent connections.
ColinTaylor
Part of the Furniture
RT-AX86U 386.5_2
The nvram variable st_max_user is shared between Samba's max connections and vsftpd's max_clients.
On the FTP GUI page the input field has an input length of two characters and is validated as 1 to 99.
On the Samba GUI page the input field appears in two different parts of the code. In the first position it has an input length of only 1 character, even though it might be set as (and display as) 99. There is conflicting code in function validForm() where st_max_user is checked at the beginning as being between 1 and 9, and then the code repeats at the end with a check between 1 and 99.
So it looks like code was added to the Samba page to support 1 to 99 but the existing code for 1 to 9 wasn't removed. (I can't think why new code was added rather than just changing the existing code.)
I have a note in my TODO list about reviewing the SMB page in particular, there are a few issues with it (particularly following the 47885 merge). I haven't had time to look at it yet.
Saw that the recent update (386.7) allows 99 concurrent connections in the GUI, up from 9 before. Thanks.
There is still a bug however in the user permissions shown for R/W, R, and No columns. I have two USB sticks attached to an RT-AC68U, and the stick on the USB2.0 port has two partitions. One FAT32, and the other NTFS. The folders under the NTFS partition does not properly update permissions settings when I click between two different Samba users. I have to first refresh the page (http://192.168.1.1/Advanced_AiDisk_samba.asp) and then select the user before opening up the drives to see permissions.... possibly a quirky enough situation that it appliers to exactly one worldwide user.
