GUI Memory x Meminfo
Markfree
I noticed that the memory information shown at the router's web GUI ("Network Map > System Status") is different from the one shown by "/proc/meminfo".
I read somewhere that the web GUI used information from "free" command, but the amounts are different as well.
GUI
# free
             total       used       free     shared    buffers     cached
Mem:        440420     240544     199876       1624       5404      43320
-/+ buffers/cache:     191820     248600
Swap:            0          0          0
Why does GUI shows total, used and free memory so different from meminfo?
How is the web GUI information is collected?
GUI
# free
Swap:            0          0          0
meminfo doesn't consider memory reserved by the kernel to be available at all, so it only reports 430 MB instead of 512 MB as max memory. The Broadcom pool manager reserves 13% of the total memory for itself, for instance. The webui extrapolates the max memory to compensate for that.
The rest of the info is retrieved directly from the kernel's /proc/meminfo interface.
So, does it means that total memory shown in webui is hardcoded?
I see that meminfo's free memory data actually matches the webui data.
Does that means webui's Used memory data is just a subtraction, 512 - "free memory"?
It's rounded up to the nearest power of two.
ej_memory_usage(int eid, webs_t wp, int argc, char_t **argv){
        unsigned long total, used, mfree  /*, shared, buffers, cached, driver occupied*/;
        char buf[80];
        int from_app = 0, i = 0;
        int memSize[] = {4,8,16,32,64,128,256,512,1024};
        int length = sizeof(memSize)/4;
        unsigned long  maxSize = 0, currentSize = 0;
        from_app = check_user_agent(user_agent);
        FILE *fp = NULL;
        fp = fopen("/proc/meminfo", "r");
        if(fp == NULL)
                return -1;
        fscanf(fp, "MemTotal: %lu %s\n", &total, buf);
        fscanf(fp, "MemFree: %lu %s\n", &mfree, buf);
        fclose(fp);
        for(i=0;i<length;i++){
                currentSize = memSize[i]*1024;
                if(currentSize > total){
                        maxSize = currentSize;
                        break;
I enjoyed researching those C functions and trying to understand the code.
That was enlightning.
Thank you @RMerlin.
Just one more question...
I didn't see how "used" value is collected.
Can I assume webui's "Used" data is (512 - "mfree")?
That was just below the code that I pasted (I didn't paste the whole function):
        used = maxSize - mfree; // (maxSize - total) + (total -mfree)
