hardware physics issue rt-AC88U
J AÏE JOE
could any of you have increased the physical memory of this router? either by the change of memory or by a little DIY behind the fagots.
I thank you for your answers
have a lovely day everybody
question de physique matérielle rt-AC88U
l'un d'entre vous a t'il pu augmenter la mémoire physique de ce routeur ? soit par le changement de mémoire soit par un petit bricolage de derrière les fagots.
je vous remercie de vos réponses
bonne journée à tous
Even if you could find a pin-compatible RAM replacement, there's a good chance that the total memory size might be hardcoded in the bootloader.
I'm betting that using swapping on a router will slow things down a bunch. Not speed them up. Swapping always slows down computers. The way that Mr. Cray used to make fast computers was by putting in a gigantic amount of physical memory, no virtual memory or swapping.
I'm pretty sure it was the snazzy colours that made it go faster. :D
