Having a couple issues with AMTM things...
zekesdad
Im having two issues. 1) none of these programs (uidivstats, connmon, ntpMerliln, SpeedMerlin) are showing up on the GUI of the router. (flexqos IS showing up in the correct place) Im on the latest merlin fw, and the latest amtm. Going to Tools, they're just not there. and 2) I cant update ntpMerlin. If i type j2 it returns "Creating database table indexes..." and never moves on from that.
for ntpmerlin, can you run:
sqlite3 /jffs/addons/ntpmerlin.d/ntpdstats.db
and check if it errors? If using USB storage option try
sqlite3 /opt/share/ntpmerlin.d/ntpdstats.db
chris@RT-AX86U:/tmp/home/root# sqlite3 /jffs/addons/ntpmerlin.d/ntpdstats.db
SQLite version 3.33.0 2020-08-14 13:23:32
Enter ".help" for usage hints.
That's all i get when trying both commands.
