Hello everyone.
Here's the issue I am having. I just recently purchased the GT-AX11000 router, which I'm very pleased with. The problem is trying to connect my RP-AC68U in AiMesh mode.
When I try to use the Asus router APP to connect it as a node it never finds the RP-AC68U or through the GUI interface on the GT-AX11000.
I was able to set it up through WPS as a repeater. It would never become a solid connection with most devices connected but without internet access.
I checked to see if both firmware are up to date and it seems they are.
The firmware for the GT-AX11000 is 3.0.0.4.382.40019
The firmware for the RP-AC68U is 3.0.0.4.384.8011
Is there a compatibility issue between both devices or is there something in the settings I have to enable/disable to get this to work.
New to the AiMesh thing.
Any help would be appreciated.
