well, so true...
back to where it all started - HDD manufacturer diversity. Just ordered QNAP TS-439Pro with two WD's and two HITACHI's drives. Once I put it all together, I will update this post with the results... (remember - HITACHI I bought is not on their official web site, but their tech support said it will still work). we shall see.
well, here are the results (plus some extra observations):
1) two WDC drives in bays 1 and 2:
Hard disk model_______Western Digital Caviar Green family
Model number_______WDC WD10EADS-00M2B0
Serial number_______W -DMWVA05317777
Disk capacity_______931.51 GB
Firmware version_______01.00A01
ATA version_______ATA-8
ATA standard_______Exact ATA specification draft version not indicated
2) two HITACHI drives in bays 3 and 4:
Hard disk model Hitachi_______HDT721010SLA360 ST6O
Model number Hitachi_______HDT721010SLA360
Serial number_______TS6F40RM12JTPJ
Firmware version_______ST6OA31B
ATA standard_______Not recognized. Minor revision code: 0x29
Everything seems to work together just fine. My only concern was that "minor revision code" under ATA standard. I've asked their support via MSN chat and I even opened ticket through their web site - no response. I expected a bit better handling from a company who makes NAS'es for business... but it is a separate story.
I've noticed that HDD's in bays 1 and 2 (WDC's) are constantly а few degrees cooler than HDD's in bays 3 and 4 (HITACHI):
System temperature 28°C/82°F
HDD 1 temperature 32°C/89°F
HDD 2 temperature 32°C/89°F
HDD 3 temperature 33°C/91°F
HDD 4 temperature 34°C/93°F
the HDD in bay 4 (the right most - by the wall) is always the warmest one.
you can feel the CPU power - for sure. the management GUI is fast.
I've also played with RAID expansion RAID-1 -> RAID-5, it worked flawlessly. it took about 4 hours to complete, but I was able to access the files on NAS. Only once, in the very beginning - I've lost the connection to the shared drive, but it came back upon refresh - almost immediately - not sure what it was.
everything else seems to be functioning as expected.... If anyone have any questions about it - please let me know.
