1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Dismiss Notice
Welcome To SNBForums
HDD spindown on R7800
Discussion in 'NETGEAR AC Wireless' started by DevilzSoul, Apr 5, 2019.
  1. DevilzSoul
    DevilzSoul New Around Here
    Mar 29, 2019
    7
    I have a 4tb WD External Elements HDD (bought brand new a month ago) attached to USB port on R7800. My firmware is the Stock Netgear V1.0.2.62
    My problem is that my HDD wont spindown and constantly make noise of read/write. I have looked through all the options of firmware but I cant seem to find anything that will allow me to put USB Device on standby or sleep mode.
    is there anything I can do to resolve this (short of buying a SSD) - any other firmware that has this option built in.. will appreciate some input
  2. Gallo
    Gallo Occasional Visitor
    Sep 11, 2018
    17
    hd-idle, sd-idle, sdparm, or hdparm. you're going to have to find a version thats compatible with your firmware or just install voxel's firmware, he's got it in his repo's
    Murtaza12 and kamoj like this.
  3. kamoj
    kamoj Senior Member
    May 12, 2017
    454
    The hd-idle is available in both Netgear and Voxel FW, so it's not a big thing to solve.
    Log in to the router and run this once (to activate spindown for all disks after 30 minutes of inactivity):
    grep "hd-idle" /etc/rc.local || /bin/sed -i 's#^exit 0#/etc/init.d/hd-idle start \&\nexit 0#' /etc/rc.local
    If a shorter time, e.g. 10 minutes is preferred, run these commands once:
    sed -i 's/30/10/g' /etc/config/hd-idle
    /etc/init.d/hd-idle restart
    That should be all!
    L&LD, Sizzlechest and Murtaza12 like this.
