HE Frames Settings
Danifunker
Hi Everyone,
I have been reading a thread where rmerlin recommends to disable "HE Frames". I cannot find this setting and was hoping someone could help me locate it.
I've just got the RT-AX88U running 384.14
Is this an acronym for something?
Thanks a lot!
Hi Everyone,
Thanks a lot!
HE frames stand for high efficiency frame, they are required for wifi 6 or 802.11ax. If you want to disable it, you need to turn of wifi 6 standard and it can be done from wireless tab.
Thanks for the quick response; so you're saying to disable HE Frames I just switch the setting "802.11ax / WiiFi 6 mode" to disabled?
Thanks a lot! Btw I'm from Toronto but recently moved to southwestern ontario.
Yes, he frame is part of wifi 6, disable wifi 6 and you have disabled he frame as well.
