I have a fairly standard 2-channel, 2-radio setup:
My mobile phone, Wii etc use the "Home" WLAN. My desktop and laptop PCs use the "Home5GHz" WLAN.
Now, I frequently download large files from a Internet server to my desktop PC, using multiple parallel FTP streams. When I do this, I very often get capped at 11 mbit/s total download speed for all streams combined.
If I then reset the TCP connections a couple of times (by restarting the FTP program), then it suddenly jumps to ~48 mbit/s (which is fair given the ~50 mbit/s max speed of my Internet connection). I do not reboot the PC. Usually it's enough to wait for many minutes, or re-start the FTP program several times.
When the connection is capped at ~11 mbit/s it's an almost perfect flat line -- the speed is very even.
This is very annoying. Does anyone have a suggestion for what might be causing this? How do I troubleshoot?
The 300 mbit wireless is connected via a USB 2 port, and the WiFi link is within the same room, maybe 8 meters from AP to USB NIC. The Windows systray applet says the WiFi is connected, with 4 of 5 or 5 of 5 signal strenght, and 270 mbps line rate.
Heeelp please?
This really bugs me!
- Netgear WNDR3700 release 2 access point
- On the 2.4 GHz bands, a 54 mbit wireless network with SSID "Home"
- On the 5 GHz bands, a 300 mbit wireless network with SSID "Home5Ghz"
Heeelp please?
