First of all the scenario. I have a Huawei B715-23C router with modded firmware which allows telnet access to it from the lan side. I have a GL-MT300N attached to one of it's ethernet ports and have nord vpn running with openvpn. There is a Siemens N300 connected to the "LAN" ethernet port of the GL-MT300N so that it uses the VPN for voice traffic.
I can connect to the GL mini router using their web admin portal and use the shell to do a reverse ssh tunnel back to my laptop in the UK. The reverse ssh tunnel allows me web access to the N300 and also telnet access to the Huawei B715 but times out when I try to access the webui of the B715. I do get the correct IP in the browser window but nothing else is returned.
Could do with some help on this, thanks.
