Bufferbloat tested with DSLreports,fast.com and Waveform to ensure it isn't a site problem
Setup is cake and manual speeds set at 95%
Wireless bufferbloat under load increase of 11-25ms
LAN bufferbloat under load increase of 0-2ms
I know wireless isn't the most reliable and stable testing method but I noticed that after the latest updates (running the latest stable release) it doesn't seem to control bufferbloat/set speeds as well as before over wifi. I would set the speeds at 275/275 but once I use Wifi it would ignore those values and fluctuate between 280-290Mbps.
I also noticed an average increase of 4ms over Wifi that wasn't present before.
Any ideas what could be wrong? Did I do something wrong that could have caused the problem?
Any help much appreciated
