Help. Can not go to the Cloud Disk. Where problem?
Steklorez
Can not go to the Cloud Disk at https://xxxxx.asuscomm.com or Ip - Connection Timeout from internet. From my Asus LAN - no problem to connect.
What to do? This address even stritse router settings Cloud Disk.
I remove inadyn (Use inadyn from entware to connect ddns no-ip.)
I opening ports on the router at boot 64738 for uMurMur (installed) only.
But this package should not affect in any way to connect.
Port for Web access router 8080.
Come on and xxxx.asuscomm.com:8080 with no problems (bevore remove inadyn no problem xxxx.no-ip.org:8080 )
xxxxx.asuscomm.com not create page with Cloud Disk https://xxxxx.asuscomm.com
If i go to http://xxxxx.asuscomm.com:8082/ - i see AiCloud, but it says that you need to connect to https
Smart access and VPN for Smart access enabled - work perfect
On jffs firewall rules for uMurMur server:
#!/bin/sh
iptables -I INPUT -p tcp --destination-port 64738 -j ACCEPT
iptables -I INPUT -p udp --destination-port 64738 -j ACCEPT
AC66U Firmware:374.43
What do I do or how it works right?
Until I decide to use the problem I use pptp VPN, but the speed is very small
