Help- Cannot assess router adminstration page
leon
Hello,
I realised today that I cannot access my router via by browser. I received the error "Firefox can’t establish a connection to the server at 192.168.1.1.". I have tried this will all my computers and phones. I also tried typing http://192.168.1.1 and https....
All my devices at home work well with full internet assess. I am able to SSH to the router. I did a ps and received
httpds -s -p 8443 -i br0
I am not sure what else can I do...
I am using Asus RT68U, running Merlin 380.64_2.
Thanks in advance.
Run command 'ipconfig /all' see whether ip address changed.
Also try ping the router.
Open a command prompt and ipconfig to see what address your default gateway is.
Did you enable the allow only specified IP address on the UI?
Not sure what nvram value stores that entry. You could try disabling the https login to see if you can get back into the UI.
To disable https from telnet or ssh, use these commands:
nvram set http_enable=0
nvram commit
service restart_httpd
1.How often does this happen after your upgrade Firmware ?
2. what's the result of PS via ssh? only" httpds -s -p 8443 -i br0"?
