Hi guys,
I just got a used Asus RT-AC68U and having issues with it.
CURRENT ISSUES:
1. All buttons seem broken - So I cannot reset it. (The router arrived with this issue) - However, I am able to enter recovery mode by holding the reset button down as I turn on the device, but holding the reset when the device is already turned on does not do anything. The LED, WPS and WiFi buttons do absolutely nothing.
2. I cannot access the router via http://router.asus.com - it gives this error:
"Settings have been updated. Web page will now refresh. Changes have been made to the IP address or port number. You will now be disconnected from RT-AC68U. To access the settings of RT-AC68U, reconnect to the wireless network and use the updated IP address and port number."
The WiFi light on the router is off.
Visiting 192.168.1.1 just gets stuck on trying to load.
(Currently connected via Ethernet. DCHP with IP 192.168.1.1 - The Macbook's network settings show a green light with this address in the LAN options, so I think the physical connection is fine. I'm using a USB-Ethernet adapter, as my only computer has no Ethernet port. I think this adapter was working fine earlier today, and the router is still able to sent me an error message, so I don't think the adapter is the problem.)
What I tried:
A. At first I was able to connect to the router via WiFi and via Ethernet and see the router admin settings interface, but the physical buttons on the router did not work, and I would sometimes get the same "settings have been updated" error as above.
B. I updated official firmware via the normal router interface, this appeared to update, but did not fix the problems. After this I was still able to access the admin settings interface.
C. I installed Merlin via the Asus Recovery Tool. After doing this the router will not access the settings interface, and just gives the same error as above. The buttons still don't work, so I cannot reset it.
D. I installed stock firmware via the Asus Recovery Tool. This appeared to install successfully, but nothing has changed. I just get an error message and cannot connect to the router or reset it.
Any advice would be really appreciated. I'm a newbie so please try to explain a bit more clearly than if you were talking to a networking expert.
Thanks very much!
CURRENT ISSUES:
What I tried:
Thanks very much!
