Hi! Can anyone help with config tips please? I'm trying to configure my network as shown in the diagram.
1. I'd like the Edgerouter to be the DHCP server, only because that'd be better for DPI monitoring (I think...), though the 4G Modem warns ominously about the Optus 4G network not assigning a unique IP when I turn off its DHCP ....
2. So I thought I'd keep it simple and have everything on the one network, 192.168.1.x (255.255.255.0). That would mean setting the Modem to x.x.1.1, the Edgerouter to x.x.1.2 and the Dovado to x.x.1.3.
3. I'm using the Dovado until I can afford to buy another Unifi AP, don't judge
4. Question: which, if any, device needs to be in bridge mode?
5. Question: Can/should I set the IP address as in (2) above?
6. Question: should I set static routes between each device using addresses as in (2)?
7. What settings/wizard should I use in the Edgerouter?
I have latest firmware in each device.
NB. I've tried roughly what I've described above and guess what? .... yeah, it doesn't work!
PS. I got it working without the Edgerouter between the Dovado AP and the modem, but I want the Edgerouter in there for its Layer3 DPI firewall abilities.
Please can anybody help? Many thanks in advance!
