Help Configuring my Linksys LRT224
AndrewBuikema
Hi everybody,
I'm sorry if this is in the wrong place, I'm new to the forums but I need some help.
Long story short, I have a Linksys LRT224 for my VPN/main router and a Netgear Nighthawk x8 for wireless. I recently discovered that the LRT224 is not compatible with VoIP, so I'm switching everything over to my wireless router.
I want to turn off router capabilities for the Linksys router and still use it as a VPN router, but use the Netgear as the main router.
Is this possible?
Thank you!
Hi everybody,
Is this possible?
Thank you!
How is the LRT not compatible with VOIP?
That's because AFAIK it wasn't implemented.
Instead enable Mutlicast Pass-through and disable Block WAN Requests in the LRT Firewall section.
