DnS94
Hello!
I am need of a upgrade, right now I have a Netgear N750(WNDR4300) router and I recently moved to a two stories/stairs apartment that is 1000-1300 sqf with some concrete walls. The router is placed on first floor(biggest surface area) and works very well there but when you get upstairs you loose connection or sometimes if you are lucky might sometimes have 1 bar.
The only thing I need is that I have some kind of stable connection upstairs, it will only be used to social media and web browsing anyways and able to stream 4K on the first floor(I am able to do that right now, but its alot of buffering on Plex local stream). I have been looking at some routers, reading alot of reviews but I cant decide what the difference is and what I actually need, any help would be appreciated.
All of these routers cost almost the same where I live so price does not matter.
I am also open to other suggestions, but I live in Scandinavia so kind of limited to "mainstream" brands.
Routers I have been looking at:
ASUS RT AC86U
ASUS RT AC5300
Netgear Nighthawk X4S R7800
Linksys EA9500v2
ASUS RT AC3200
A̶S̶U̶S̶ ̶8̶7̶U̶
̶A̶S̶U̶S̶ ̶8̶8̶U̶
̶N̶e̶t̶g̶e̶a̶r̶ ̶N̶i̶g̶h̶t̶h̶a̶w̶k̶ ̶X̶6̶ ̶R̶8̶0̶0̶0̶
̶T̶P̶ ̶L̶i̶n̶k̶ ̶A̶r̶c̶h̶e̶r̶ ̶C̶3̶1̶5̶0̶
̶T̶P̶ ̶L̶i̶n̶k̶ ̶A̶r̶c̶h̶e̶r̶ ̶C̶3̶2̶0̶0̶
Thanks!
ASUS RT AC86U
ASUS RT AC5300
Linksys EA9500v2
ASUS RT AC3200
A̶S̶U̶S̶ ̶8̶7̶U̶
̶A̶S̶U̶S̶ ̶8̶8̶U̶
Thanks!
