help for open port in firewall
Rooby
Hello
I need some help for opening a port in WAN firewall.
My situation is a router cacade
internet FritzBox (LAN range: 10.10.10.0) <-> WAN(10.10.10.10) Asus router (LAN range: 10.10.1.0)
Additionally on the Asus router OpenVPN is running which connects to other routers.
Now on the Fritzbox I have connected a raspberry (10.10.10.2) which I want to communicate to my NAS over the Asus router via OpenVPN.
Everything is working if I disable the WAN firewall on the Asus router but I do not want to disable it completely.
I want to make an exception only for for theRaspberry.
When Itry to mount my NAS (10.10.2.2) on the Raspberry then I get the Asus syslog entry:
May 15 22:15:17 kernel: DROP IN=eth0 OUT=tun21 MAC=a8:...... SRC=10.10.10.2 DST=10.10.2.2 LEN=60 TOS=0x00 PREC=0x00 TTL=62 ID=47224 DF PROTO=TCP SPT=45328 DPT=445 SEQ=739216649 ACK=0 WINDOW=64240 RES=0x00 SYN URGP=0 OPT (021405....) MARK=0x8000000
On the Asus router I configure port fowarding for SMB using TCP and port 445 to destination 10.10.2.2 but anfortunately this did not work.
Can someone help?
Where did 10.10.2.2 come from?! All I see from the initial part of the description is two local networks; 10.10.10.0/24 and 10.10.1.0/24 (at least I assume they're /24, you weren't specific).
I assume we're talking about OpenVPN *server* here as well.
Yes the Asus router is the server and 10.10.2.2 is LAN on a second Asus router connected via OpenVPN.
But this is not a problem. It is the WAN firewall which blocks the access.
The route is then
FriFritzBox (LAN range: 10.10.10.0) <-> WAN(10.10.10.10) Asus router (LAN range: 10.10.1.0) OpenVPN <-> Second Asus router (LAN range: 10.10.2.0)
Raspberry (10.10.10.2) <-> NAS (10.10.2.2)
But the problem is the WAN firewall when I disable it everything works well and the Raspberry cann connect to the NAS.
So I need to know how to enable this exception. Port forwarding seems not to work.
After a long search I find the solution.
I added WAN port fowarding of 445 (SMB).
And add the following iptable entry to accept fowarding of local adresses from eth0 to tun21:
iptables -Ie FORWARD 9 -t filter -i eth0 -o tun21 -p tcp -s 10.10.0.0/16 -d 10.10.0.0/16 -j ACCEPT
In my case I added this on the position 9 before the local chain "logdrop" where all unhandled packes gets dropped.
