[Help] Installing No-Ip update client.
Does it say this:
admin@<router-name>:/tmp/home/root# make
-sh: make: not found
since you want DDNS, it's probably safe to assume you have a server listening on your lan. why not install the ddns client onto the server itself?
Actually, no. I have installed ftp server on the router to remotely access my files on External HDD that is connected to the USB port of the router.
The router has a ftp server inbuilt, is that what you mean ?
you could try this;
here; i haven't tested anything yet, but adding this to /jffs/scripts/wan-start should fix the router in router mode, so that the WAN port is bridged and will allow LAN traffic to pass. set the LAN gateway IP in the script. use the webui to set the router's LAN IP/subnet to something different on your LAN, while setting the static WAN IP to gibberish
#!/bin/sh
# set the LAN gateway IP to $default
default="192.168.0.1"
# nuke eth0 settings
ifconfig eth0 0.0.0.0 up
route default gw $default
# fix the WAN port
brctl addif br0 eth0
chmod a+rx /jffs/scripts/*
think of it as AP mode, but with the features of router mode still enabled
yeppers.
make sure to set the lan ip of the router like you would for AP mode, but set the gateway ip in the script to the main router's LAN ip
yeppers.
Hi again,
I tried your suggested method. However, am running into a strange problem. As soon as I write to /jffs/scripts/wan-start and then execute chmod a+rx /jffs/scripts/* and then reboot the router, i'm unable to access neither the webui nor my main router. This what I wrote to wan-start using nano
#!/bin/sh
default="[B]192.168.1.1[/B]"
# fix the WAN port
For the WAN settings, I set Static IP to 123.123.123.123 and subnet 255.255.255.0 and default 192.168.1.1
I had to do hard reset to restore communication. My Asus Router IP is 192.168.1.10
thanks, i will look into it tonight. i suspect that eth0 needs to be dropped from the bridge and a vlan interface be created in it's place, after looking at one of my routers using dd-wrt
[edit/]
#!/bin/sh
# fix the WAN port
vconfig add eth0 2
brctl addif br0 vlan2
the above is the modified version that i suspect corrects the problem
[edit/]
#!/bin/sh
# fix the WAN port
vconfig add eth0 2
Awesome, it worked. Now am able to connect to the main router and internet when the main router LAN cable is connected to one of the asus Ethernet ports. But, If I connected the LAN cable, that is coming from the main router directly to WAN port am not able to access my main router, only the asus router. Also, should I disable firewall/NAT? I disabled DHCP.
looks like there was more to it than i thought, think vlan (un?)tagging has to be disabled, give me a few and i'll edit this post
#!/bin/sh
# fix the WAN port
robocfg vlan 2 ports "0 8"
vconfig add eth0 2
i *think* this might do the trick lol
#!/bin/sh
# fix the WAN port
vconfig add eth0 2
Unfortunately, it didn't work. Can't I use DDNS without it? I mean I just plug main cable to Ethernet port.
