I have an HP NC360T dual port network card that I recently got off of ebay. I have purchased a number of these cards before and never had a problem with any of them.
I was intending to use this particular card in a small ESXi system. After I installed the card and booted up ESXi I found the card was not recognized. Normally if you add a network card ESXi will recognize it without any extra steps assuming built-in drivers are available for the card. Which they are in this case.
Further testing revealed that no other operating system would recognize the card. I also ran Intel's DOS based diagnostic program which also did not see the card. Apparently it is not even visible on the PCIe bus.
Both activity/link LEDs are permanently lit green, regardless of whether a cable is plugged in or not. The link speed led is permanently off on both ports, also regardless of cable status.
I tested the card in 3 different slots on my motherboard, with the same result. Other cards work fine in the same slots.
I am pretty sure the card is broken, but before I go through the entire eBay returns routine I thought I would check here if anyone else has had this problem.
I don't think the link / activity LEDs should be lit unless there is an active cable connection. This probably indicates a problem with the card.
Do you agree?
Do you agree?
