Lost_Animal
I have a very strange Problem.
I can't access my router via LAN.
WAN is not working !
Is only accessible via WiFi but again no WAN is up.
On the log files i see that USB is failled with error 79 and all NAT and WAN are down.
I can do FW Upgrade - Change CFG - can access it via telenet, but only via WiFi.
Lan don't answering on Ping and olny switching (Switch Box) is working.
What can i do now ? Is HW fail and i have to forget it ? or some trick can revive it ?
Here is the log file....
Dec 31 12:00:06 kernel: CPU revision is: 00019749
Dec 31 12:00:06 kernel: Determined physical RAM map:
Dec 31 12:00:06 kernel: memory: 07fff000 @ 00000000 (usable)
Dec 31 12:00:06 kernel: memory: 08000000 @ 87fff000 (usable)
Dec 31 12:00:06 kernel: Built 1 zonelists. Total pages: 585216
Dec 31 12:00:06 kernel: Primary instruction cache 32kB, physically tagged, 4-way, linesize 32 bytes.
Dec 31 12:00:06 kernel: Primary data cache 32kB, 4-way, linesize 32 bytes.
Dec 31 12:00:06 syslog: module ledtrig-usbdev not found in modules.dep
Dec 31 12:00:06 syslog: module leds-usb not found in modules.dep
Dec 31 12:00:06 kernel: PID hash table entries: 2048 (order: 11, 8192 bytes)
Dec 31 12:00:06 kernel: CPU: BCM5300 rev 1 pkg 0 at 600 MHz
Dec 31 12:00:06 kernel: Using 300.000 MHz high precision timer.
Dec 31 12:00:06 kernel: Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
Dec 31 12:00:06 kernel: Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
Dec 31 12:00:06 kernel: Mount-cache hash table entries: 512
Dec 31 12:00:06 kernel: PCI: Initializing host
Dec 31 12:00:06 kernel: PCI: Reset RC
Dec 31 12:00:06 kernel: PCI: Fixing up bus 0
Dec 31 12:00:06 kernel: PCI/PCIe coreunit 0 is set to bus 1.
Dec 31 12:00:06 kernel: PCI: Fixing up bridge
Dec 31 12:00:06 kernel: PCI: Enabling device 0000:01:00.1 (0004 -> 0006)
Dec 31 12:00:07 kernel: PCI: Fixing up bus 1
Dec 31 12:00:07 kernel: PCI/PCIe coreunit 1 is set to bus 2.
Dec 31 12:00:07 kernel: PCI: Fixing up bridge
Dec 31 12:00:07 kernel: PCI: Enabling device 0000:02:00.1 (0004 -> 0006)
Dec 31 12:00:07 kernel: PCI: Fixing up bus 2
Dec 31 12:00:07 kernel: IP route cache hash table entries: 4096 (order: 2, 16384 bytes)
Dec 31 12:00:07 kernel: TCP established hash table entries: 16384 (order: 5, 131072 bytes)
Dec 31 12:00:07 kernel: TCP bind hash table entries: 16384 (order: 4, 65536 bytes)
Dec 31 12:00:07 kernel: highmem bounce pool size: 64 pages
Dec 31 12:00:07 kernel: Amd/Fujitsu Extended Query Table at 0x0040
Dec 31 12:00:07 kernel: Physically mapped flash: CFI does not contain boot bank location. Assuming top.
Dec 31 12:00:07 kernel: Found an serial flash with 0 0KB blocks; total size 0MB
Dec 31 12:00:07 kernel: sflash: found no supported devices
Dec 31 12:00:07 kernel: dev_nvram_init: _nvram_init
Dec 31 12:00:07 kernel: _nvram_init: allocat header: 2183856128, size= 65536
Dec 31 12:00:07 kernel: u32 classifier
Dec 31 12:00:07 kernel: OLD policer on
Dec 31 12:00:07 kernel: Netfilter messages via NETLINK v0.30.
Dec 31 12:00:07 kernel: nf_conntrack version 0.5.0 (2048 buckets, 16384 max)
Dec 31 12:00:07 kernel: ipt_time loading
Dec 31 12:00:07 kernel: ip_tables: (C) 2000-2006 Netfilter Core Team
Dec 31 12:00:07 kernel: net/ipv4/netfilter/tomato_ct.c [May 17 2013 18:45:17]
Dec 31 12:00:07 kernel: ip6_tables: (C) 2000-2006 Netfilter Core Team
Dec 31 12:00:07 kernel: VFS: Mounted root (squashfs filesystem) readonly.
Dec 31 12:00:07 kernel: Warning: unable to open an initial console.
Dec 31 12:00:07 kernel: ctf: module license 'Proprietary' taints kernel.
Dec 31 12:00:07 kernel: et_module_init: passivemode set to 0x0
Dec 31 12:00:07 kernel: eth0: Broadcom BCM47XX 10/100/1000 Mbps Ethernet Controller 5.110.27.20012
Dec 31 12:00:07 kernel: wl_module_init: passivemode set to 0x0
Dec 31 12:00:07 kernel: PCI: Enabling device 0000:01:01.0 (0000 -> 0002)
Dec 31 12:00:07 kernel: eth1: Broadcom BCM4331 802.11 Wireless Controller 5.110.27.20012
Dec 31 12:00:07 kernel: PCI: Enabling device 0000:02:01.0 (0000 -> 0002)
Dec 31 12:00:07 kernel: eth2: Broadcom BCM4331 802.11 Wireless Controller 5.110.27.20012
Dec 31 12:00:07 kernel: Algorithmics/MIPS FPU Emulator v1.5
Dec 31 12:00:07 kernel: NTFS (with native replay) support included
Dec 31 12:00:07 kernel: optimized: speed
Dec 31 12:00:07 kernel: Build_for__asus_n66u_2011-10-27_U86_r187446_b122
Dec 31 12:00:07 kernel: ohci_hcd 0000:00:04.0: init err (00000000 0000)
Dec 31 12:00:07 kernel: ohci_hcd 0000:00:04.0: can't start
Dec 31 12:00:07 kernel: ohci_hcd 0000:00:04.0: startup error -79
Dec 31 12:00:07 kernel: ohci_hcd 0000:00:04.0: init 0000:00:04.0 fail, -79
Dec 31 12:00:07 kernel: ohci_hcd: probe of 0000:00:04.0 failed with error -79
Dec 31 12:00:10 stop_nat_rules: apply the redirect_rules!
Dec 31 12:00:10 syslogd started: BusyBox v1.20.2
Dec 31 12:00:10 dnsmasq[444]: started, version 2.65 cachesize 1500
Dec 31 12:00:10 dnsmasq[444]: compile time options: IPv6 GNU-getopt no-RTC no-DBus no-i18n no-IDN DHCP DHCPv6 no-Lua TFTP no-conntrack
Dec 31 12:00:10 dnsmasq[444]: asynchronous logging enabled, queue limit is 5 messages
Dec 31 12:00:10 dnsmasq-dhcp[444]: DHCP, IP range 192.168.1.2 -- 192.168.1.254, lease time 1d
Dec 31 12:00:10 dnsmasq[444]: read /etc/hosts - 5 addresses
Dec 31 12:00:10 WAN Connection: Ethernet link down.
Dec 31 12:00:10 syslog: Password for 'admin' changed
Dec 31 12:00:10 RT-N66U: start httpd
Dec 31 12:00:10 RT-N66U: start httpd - SSL
Dec 31 12:00:10 syslog: Generating SSL certificate...
Dec 31 12:00:10 crond[466]: crond: crond (busybox 1.20.2) started, log level 8
Dec 31 12:00:11 Samba Server: daemon is started
Dec 31 12:00:12 disk monitor: be idle
Dec 31 12:00:12 nmbd[506]: [2010/12/31 12:00:12, 0] nmbd/nmbd_become_dmb.c:become_domain_master_stage2(113)
Dec 31 12:00:12 nmbd[506]: Samba server RT-N66U is now a domain master browser for workgroup WORKGROUP on subnet UNICAST_SUBNET
Dec 31 12:00:20 nmbd[506]: [2010/12/31 12:00:20, 0] nmbd/nmbd_become_dmb.c:become_domain_master_stage2(113)
Dec 31 12:00:20 nmbd[506]: Samba server RT-N66U is now a domain master browser for workgroup WORKGROUP on subnet 192.168.1.1
Dec 31 12:00:21 pppd[515]: Plugin rp-pppoe.so loaded.
Dec 31 12:00:21 pppd[515]: RP-PPPoE plugin version 3.11 compiled against pppd 2.4.5
Dec 31 12:00:21 pppd[516]: pppd 2.4.5 started by admin, uid 0
Dec 31 12:00:35 nmbd[506]: [2010/12/31 12:00:35, 0] nmbd/nmbd_become_lmb.c:become_local_master_stage2(392)
Dec 31 12:00:35 nmbd[506]: Samba name server RT-N66U is now a local master browser for workgroup WORKGROUP on subnet 192.168.1.1
Dec 31 12:00:56 pppd[516]: Timeout waiting for PADO packets
Dec 31 12:02:11 pppd[516]: Timeout waiting for PADO packets
