Help needed in resetting EA-N66 Dual-Band 450Mbps
trumpeter96
I have a EA-N66 and i need help getting it to factory default. I tried turning off the power, hold onto the reset button and then power it on while holding onto the button for about 15second. I also tired it with the WPS button but both doesn't seem to work. I use the discovery tool and it cant find the AP to configure it. I have the connection of my PC set to DHCP and the result i get is, IPv4 Address: 169.254.205.219 , Subnet Mask: 255.255.0.0 . I am unable to get a default gateway.
Specify the PC's connection as 192.168.1.100 instead of using DHCP.
Thanks for the help! But it still does not work
So i set my IP as 192.168.1.100/24 right? After doing that i still can't connect to the AP. I try with and without the gateway of 192.168.1.1 and both doesn't work. I will get a Unidentified network.
By the way, this problem occur because the WPS button was pressed. After the button is press, i can't get into the AP anymore.
