Hi y'all,
I've bought an Asus RT AX55 for wireless VR gaming. When it works, it works great! We have fiber at our building and whenever the router is fine I get around 900 megabits on speedtest.
Unfortunately, I've been dealing with a problem concerning speed which also ruins both my fast internet and my VR experience. For some reason ̶a̶l̶l̶ (EDIT: New results showed that it only applies to a certain device. The other device was always 100mbps limited) my LAN ethernet ports (WAN is fine) keep dropping to 100mbps after a while. If I reset the router, it turns back to 1gbps but around ~30 minutes later its back at 100mbps. I can notice this in VR because I suddenly get a huge delay in tracking movement.
I have absolutely no idea what causes this, I've tried a handful of things which didn't work. Here is the list:
- Updating firmware
- Swapping ethernet cables (They're all good quality as far as I know, one of them is a new bought cat6)
- Changing wire path to make sure my HDMI cable that takes the same path wasn't disturbing the ethernet cable
- Using the router without being connected to the internet, but even then after a while they cap back to 100mbps
- Changing LAN ports
I'm kind of lost, don't know what else to try. Maybe someone here can help me out with this problem
Thanks in advance!
- Updating firmware
Thanks in advance!
