I have the following Setup.
The problem is that my ethernet speed drops from 1Gbps to 100 Mbps. I have checked both plugs of the cables and the sockets and they are all clean. If I do a line test using a simple cable tester all 8 lines are showing correct and the speed return to 1Gbps for a while before dropping.
It was suggested on another forum that I should instal a simple switch so I bought a TP-Link TL-SG105S 5-Port Desktop Gigabit Ethernet Switch, and put this at the Virgin Box end. All was working great speed stayed at 1Gbps all day, checked this morning back down to 100 Mbps.
I have just done the line check again, it was back at 1 Gbps for about 5 mins then dropped back again
Now I presume this is a speed negotiation problem maybe due to the cable, am I right? If so is the only choice to replace the cable?
- Virgin SuperHub 3 operating in Modem Mode
- 60M of external CAT5E cable running to
- Asus RT-86U Running Merlin
