Help Reading Syslogs - Possible Hack - Logs Showing Ports Entering Promiscuous Mode
zwitterion
This would be the second time my router (info found below on signature) completely stopped receiving both wireless and wired connections. When looking at the syslog I found ethernet ports being set to Promiscuous Mode and Entered Listening State. When searching online I found "promiscuous mode means a packet sniffer instructed your ethernet device to listen to all traffic. This can be a benign or a malicious act." If this is a bug issue, then I can post this elsewhere as well to help with resolving the matter.
Promiscuous mode is what happens when you engage tap/monitoring of the port/packet. I use ntopng and that's how you get the info. Are you using a package in the router for this purpose?
I don't think so, I just have Diversion, Skynet, and scribe installed. I used to have Kiwi Syslog but that was setup before I moved to Merlin and the configs may have been transferred in the dirty firmware upgrade. I no longer use Kiwi syslog since I have Scribe installed
I glanced at the attachment after replying and it looks like an 8 minute boot log. Looks like normal stuff with interfaces coming online. Maybe a hard reset and manual reconfiguration bis needed. It didn't show any obvious app being triggered. Maybe it did a soft reboot to trigger things due to an error?
Possibly, not sure what causes soft reboots. I am getting regular patterns of these syslogs:
Mar 30 21:12:22 GT-AXE11000-7220 kernel: FPM Pool 1: invalid token 0x205f0000 freed
Mar 30 21:12:22 GT-AXE11000-7220 kernel: FPM Pool 1: ISR timer is enabled. There could be multiple occurrences of the reported issue
Mar 30 22:09:46 GT-AXE11000-7220 kernel: httpds (2617): drop_caches: 1
and one of these:
Mar 30 22:19:44 GT-AXE11000-7220 kernel: htb: too many events!
if it becomes a bigger problem I can wipe everything and install clean firmware
Httpds is the web server package for reporting something from an app. I also run pihole for monitoring dns traffic and it's bundled into that for the web GUI. There might be a conflict from the dirty upgrade between the two programs. A surefire way to figure it out would be a netstat to see what's listening / serving web stats from an ssh session.
