Help setting up IPV6
jasons6930
Hi Guys,
Currently running a Draytek 2862 in bridge mode, along with an ER4 for routing duties.
I have just signed up to an ISP that also gives out IPV6 so i would like to configure everything ready for the switch over in a week or two.
The 2862 currently has IPV6 enabled, so i am assuming i need to turn this off.
And also, on the ER4, should I just run the setup wizard again and select ipv6 from there for ease?
Is there anything else i should do?
